Is it possible
Ok I want to know if you can put the subframe from the 2010+ models on the 3rd gen frame that my bike uses? If not could I modify the plastics to fit? Could I directly bolt on the 2010+ tank? Or would I need a custom tank, or could I modify the plastics. I want to give the bike a refreshing newer look like the new bikes, since honda won't build it themselves.
heat gun could help you shape the tank if need be.
You'll need the 2010 airbox to run the the parts too.. it would be tricky to pull off
Would the airbox bolt in with some modding of the subframe. Or does the 2010 subframe fit, could I use the 05+ cr125 airboot with the 2010 air box? Hopefully the tank is not to hard.
Unless you know how to weld aluminum, it wont happen. After that, it would be a lot of plastic molding, shaping etc.
