help 02 cr250 shiwa spring removal!?!?!?!
Trying to remove my 02 cr250 rear shows spring .. when I unloaded the two pre load clips and lifted the spring up I'm not sure how to remove the spring seat and stop clip .. where the lower mount is it it screws in but will the oil leak out ?
Lift up the bottom "ring," that the spring sits on, off the cup piece and you should see a circlip. Remove the circlip, then remove the bottom spring seat, and then the spring should slide right off. Let me know if this isn't clear or doesn't make sense.
