Front brake rotor stud patten
Hello all,
Can anyone tell me if there is any difference in the mounting hole patten between an E, S and SM.
I ask because I am trying to get a 320mm Beringer rotor and the guy selling asked me if I have a S or SM. So to totally confuse him I told him I had an 07 E with Behr rims and RAD hubs (the wheels off the old TT 475). I believe the hole patten is the same across all models but I thought I would double check here.
Thanks in advance.
Luke
  • No difference, the S, E and SM all use the same hubs, front and rear.
  • The E and S use the same diameter rotors front and rear, same calipers, mounts and fork leg positions.
  • The SM uses larger rotors front and rear, same caliper on front.
  • The SM uses a different rear caliper, caliper mount then the E or S.
