Suspension spring options
So I had bought a '09 150RB for someone else, but now need to make it ride-able for myself next summer. Since suspension is something I know little about, what is the current consensus on best spring manuf. & setup for forks/rear that I can start with before doing valve work? Weight is 175lbs with gear and strictly single track. Is anyone going stiffer than recommended?
Thanks
I went with Factory Connection springs on mine. I weigh about 150, and went right off what they recommended. I don't recall the weights I went with but I used their chart, and called them as well. I rode it without re-valving it for a summer just to see if I could save a little money......... definitely doesn't work. Get it re-valved. You might even want to call the company you are going to use for the re-valve and see what they recommend for the springs.
Good Luck!
