06 rm125 fork oil
Hi. I am helping a friend out with his 06 rm125 forks and was wondering how much oil to put in after I replace his seals. thanks.
I have written down 362cc for the outer chamber, but you can start with 340-350cc per leg
I am getting this info....from an 05 250 manual. But should be close.
Standard springs 0.44.....standard oil....350ml ( range of 310-405ml).
I would think that standard on the 125 would be 0.42 front spring......and the 250 manual for that spring....is 355ml standard....and a range of 315-410ml.
Of course....I watch the you tube video...on showa forks....to get the inner chamber filled and the air bled.
Also ....I have a 05 125....with .44 fork springs.....just found a note in the manual....I put in 320ml ...and the forks feel good for off-road. Using 5wt oil.
out
