Basic maintenance help needed :D
I was wondering if there were any good tricks or hints when flushing out radiators
Cheers
No real tricks.. just take off your top.. the drainhole bolt.. get some of this..http://www.rockymountainatvmc.com/productDetail.do?navType=type&webTypeId=41&navTitle=Chemicals&webCatId=23&keyword=radiator+flush&prodFamilyId=31923.. flush it out.. and fill with some of this..http://www.rockymountainatvmc.com/productDetail.do?navType=type&webTypeId=41&navTitle=Chemicals&webCatId=23&keyword=honda+radiator+fluid&prodFamilyId=11713.. put ur top on and ride.
Or flush with distilled water and vinegar and use the extra $5 bucks to get yourself a happy meal to celebrate. Even tap water would be okay to flush with since it will be drained only after a couple of minutes.
When flushing out the radiator with vinegar and distilled water do i do a 50/50 mix
That ratio will be fine. Doesn't need to be exact.
