250x Buzzing relays & shorting dash
Hi Guys, so my 250x has been sitting in my shed for about a fortnight, with a flat battery, when I kicked it over today both the headlight relay and the main relay were buzzing (toggling on and off) and the dash seemed to be shorting out..
Any idea what may have caused this? and whats going wrong?
I suspect a dodgy reg/rec..
Cheers
Cant be the battery, I removed it and tested it, same issue. 12-14v at the terminals depending on rpm.
Thanks for the reply though mate
Test the battery when you don't have the bike running. Or put it on a charger and see if it will accept a charge. If it doesn't, get a new battery.
P.S you will have the same symptoms riding without the battery.
Sorry mate, just worked out not having a battery in at all will be cause the buzzing.. battery seems to hold a charge initially after a trickle charge, but I might replace it just to be certain. Its pretty old
