Cr To CRF suspension HELP???
only thing you will need to change on the suspension would be the shock clevis.
For the front you will need the brake caliper bracket for the later forks. 05+
Mog had the shock lengths listed.I'll try to find it. Tbc.
Here it is..
here you go, intreresting reading
cr shock lenghts
2001 Cr125 (I think to current)
486 length stroke 138.6mm
2001-2002 cr 250
Although this list doesn't show the newer crf250's I should mention I have an 07 crf450 shock on a 03 cr250 that works perfect. Fact connection verified fit interchangeability and valved the shock.
488 /134.5
2005-2008 cr 250
498/133
2002 cr 450f
483.5/133
2004 450f
483.5/133
2007 CRF450
489/135
2005 crf 250
498/133
on 08 crf450 shock bolted right up to my 01 cr250 ..works great !
and more than likely there is a difference in length due to the shock clevis which will change the handling on the bike. Unless you know why you would want/need to do this, you could have made the bike worst handling.
BRAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAP! theyll fit other than the caliper up front. and the rear shock will fit too but the adjustment will snug under the plastics. Braaap brraaappppppppppppppp Take my word squirt
it works great, the ride height didn't change much, just adjust the sag and i was good to go, it was a great upgrade over the 01 shock IMO:ride:
Here it is..
cr shock lenghts
2001-2002 cr 250
488 /134.5
2005-2008 cr 250
498/133
2002 cr 450f
483.5/133
2004 450f
483.5/133
2007 CRF450
489/135
2005 crf 250
498/133
Sorry to bring up an old topic, but could someone please verify something for me. I see that according to the list above, the shock on the 2005-2007 CR 250 they are the same lengths. It also lists the 2005 CRF 250 as the same specs as the 2005-2007 CR 250. My question is, do you know if the 2004 CRF 250 is the same shock as the 2005 CRF 250? Long story short, I'm needing to verify if a 2004 CRF 250 shock will bolt up to my 2006 CR 250.....are the clevis' the same length and are the eye to eye measurements the same length? Thanks if someone can help!
