TM 125 Spluttering at powerband possibly jetting issue?
I bought a 1998 Tm 125 about a month ago was running great up until a week ago. Now it's lost abit of low end power and splutters when it hits the powerband.
It does seem to be worse when under-load In neutral it revs ok most of the time. I've put new spark plug in, changed ht lead and cap, cleaned all electrical connections and earths, put fresh mix of fuel in, cleaned the air filter, carb, checked the reeds, checked the power valve operation tested the spark nice and blue and it had a top end rebuild the week before I bought it and has been run in correctly
It ticks over and is fine upto half throttle but splutters at full throttle in the higher rev range which makes me think the jettings out. But I'm confused as it ran perfect on it's current setting when I bought it.
Does anyone know the factory jet sizes for the 98 tm with the keihin carb?
Or does anyone have any ideas what else could cause it to splutter?
Any help appreciated
Edited by afireinsideme
Error In title
Its not your jetting as it ran fine before. Check your compression, Make sure your coil is grounded well, check your power-valve and actuation arm / spring.
K
I have booked it in for a compression test on Tuesday what kind of psi is acceptable? As I say the top end is quite fresh and it starts and idles fine which makes me think the compression is ok but I could be wrong. I've cleaned all terminals and the powervalve moves freely and opens fully when it should. I've been told it could be the stator, cdi or coil at fault is there anyway to test these? I have an electrical tester just unsure what wires to test and what it is I'm testing for
sounds like you are on it and narrowed down to possible electrical issue. :bonk:
It sounds like an electrical issue it's kind of misfiring aswell as spluttering at full throttle. I did some welding to the exhaust recently whilst it was on the bike but it seemed to run ok after. I forgot to unplug the cdi could it have damaged it? I thought cdi's tend to either work or not work. It's not something I can just borrow from a friend to test on my bike as I don't know any Tm owners and used parts are very hard to find
coil would. Replace it, many will work. Get one off another 125 or 250 2 st
Ok thanks i have a kx 250 87 coil that I know works I'll try it in the morning and report back. Any other suggestions welcome
No problem, good luck :bonk:
I've checked the reeds were in good shape and sealing good. I've been bedbound with flue for a few days so I've still to change the coil over with my kx one
