Need some help identifying an engine.
I recently purchased a four wheeler and it had an engine swap done and the person i got it form told me it was a 1995 yz250 engine but some parts are not simmilar to what I receve from parts. I was wondering if there was any Numbers on the engine that can help me figure out what it really is. I can guarantee it is a yamaha 2 stroke but everything else is questionable.
Thanks,
Josh
P.S. This is my first post on here Thanks agin for the help
Look on the drive side of the motor, in that general area. There should be a serial # with letters and numbers: JX12345... for example. Post up that # in here.
If you could post up a few pictures I'm sure someone on here will tell you what it is within a day.
Good luck
What DESERTKID said. :banana::bonk:
There will be a 3-digit code in various places on the motor, like 3V2-, or 4SS- or something like that. Check the base of the cylinder on the shifter side for "4MX00" right next to "249cm".
While sometimes not exact, those numbers will help narrow down which year the motor is.
And a picture will be worth a thousand posts. :smirk:
Welcome to ThumperTalk, Josh!
How do you post pictures lol sorry like I said I am new here lol I have a couple pictures tho and I am cleaning off the engine I found one set that says 5x50.0 or 500 y-1 and I am still looking for the vin
You should find something engraved like 4MX for a 95 250 on the left side of the cylinder and also on the case half on that side. My bike is a 91 and the numbers are 3XK engraved all over the bike. If its not 4mx it prob isnt a 250, or not a 95. Source: http://craigmac215.tripod.com/yzmodels.htm
http://imageshack.us/photo/my-images/51/1000333p.jpg/ Here is a tempoary pic...
...I picked everythign up for $150 so can't complain too much.
Looks to be a YZ250 (or Tri-Z?) cylinder from anywhere between 1982 and 1987, according to drawings in the parts lists...
http://www.cyclepartswarehouse.com/fiche_select.asp?srt=mfg
...and a Bing image search...
http://thumbs1.ebaystatic.com/m/mlN_FzJaLUNUwenTsTMWIpQ/140.jpg
Not sure how else to narrow down the exact year without a serial number or year code.
Looks to be a fun project!
Thanks alot for the help guys, I will get a serial number soon and a couple more pictures like I said, and it is a really fun project thans. And what is a Tri-z I was fairly sure it was a yz250 so thanks agin! :bonk:
http://imageshack.us/photo/my-images/51/1000333p.jpg/ Here is a tempoary pic I will get some more later and sign up to photobucket and upload them there. The flywheel cover is off in this one because I am replacing the flywheel key, I know everything is kinda rough but I picked everythign up for $150 so can't complain too much.
Right above the flywheel on the part of the case parallel to the ground should be some numbers or letters. Looks like its covered by dirt... But it should be right there.
...And what is a Tri-z I was fairly sure it was a yz250 so thanks agin! :bonk:
A Tri-Z was Yamaha's first high-performance ATV...
http://www.yamaha-motor.com/outdoor/epic_atv/1985_triZ250_small.aspx
...it used what was basically a YZ250 motor.
The flat area right behind the kickstart lever should have a string of numbers. That will be the serial number for the motor.
Whoo! It looks like you have your work cut out for you!
I'll be washing it soon lol just have to find my pressure washer but believe it or not it actually runs pretty good. just some minor issues with carb leakage, and the flywheel key got demolished lol But the new one will be installed once my puller gets here..... :bonk:
I found the numbers!!!:bonk: they are 1LU-001142 they were caked in dirt a mile deep lol.
1986 yz 250. not the 95 you thought you had, but at least you know now.
