Jet help
I put a high compression piston in my 2009 SSR 125 engine, it now is running a little lean, so I want to swap out the jets. I am having a hard time figuring out which jets to order. My carb is a keihin with a 36mm in and 26mm out. Can anyone help?
It appears to be a Chinese clone of the Keihin 17mm carb used on the XR/CRF70, but that doesn't mean that you can use the Keihin jets in your carb. The best advice I can give you is to post up some pictures of the main jet and pilot jet alongside the metric edge of a ruler, to get an idea of size and dimensions. Also, see if the jets have a size number on them, and post your findings.
I have a few different Chinese carbs here, possibly be able to see if your carb uses the same type and style of jets.
