Problem with clutch
The bike is -04.
I did a rebuild for the engine and now when I tighten the clutch basket nut to 70nm the inner part does not move if I hold the outer part like it should.
There are sliding marks on the big washer what is located in the center of basket parts.
The parts are like they should be.
Solved:
The washer has little grooves on it, maybe the nut has been loose past.
I flipped the washer other way and now it works, have to order a new one.
