No spark yz250
I have got some problem with my yz, no spark att all last rides it was a pain to kickstart then when i pushedstarted it it fired up. now i got no spark. any you guys that had problems like this?
Now i changed Ignition coil, stator and the CDI unit. checked the wires with a multimeter and it all seems fine. i realy can´t understand why it won't give spark?:bonk:
forgot to say it an 2009. also changed the killswitch checked the neutralsensor.
spark plug si new, wire also i have cheched all komponents there fine (new) also have cheched them with a multimeter as the manual says. recistance is in ok. the cable tree fine no shortage to anything. im thinking of cutting the cable tree open? but it's is fine tho.
doe s someone know how much volts the stator supposed to genarate?
and how i can chech if it's producing enough?
If all checked out all parts over the resistance it is hard to determinate the fault.
I would not open the cable tree. Rather clean all connectors and make sure you have a nice negative connection.
