KLX110 Fork Disassembly Problem
Hi, Newbie here...
I am installing BBR springs on my son's KLX110. I removed the circlip and "plug" from the right fork without a problem but when I went to remove the plug from the left fork it seems to be lodged in the fork tube. It won't budge in either direction.
Has this happened to anyone else? Any solutions?
Thanks in advance!
The "plug" only goes down a few mm before it'll get wedged into the top of the fork tube. I wish I had a good idea for you. You might try drilling and tapping it so you can install a bolt to pull it out. I'd think before you completed all that, it would get twisted loose.
I was afraid of that...
Thanks for the advice. I'll try the drill/tap method.
