06 crf250r burning oil? need help!
alright well i have an 06 crf250r and i had it fully rebuilt, top and bottom end... i broke it in and it was running good until it randomally started smoking, bluish smoke burning oil... so i have changed the gas,replaced the rings, replaced the valve seals, replaced the right crank seal, and have checked the valves, cylinder, and valve seats and they are all good. seats are sealing perfect... so does anyone have any other ideas what it is? i just got done replacing the right crank seal and thought it was good to go then i started smoking again... also it is mostly just smoking after it is warm when you give it gas....and no i dont have premix in its... so any other ideas of what it could be? im about ready to split the cases to replace the left crank seal if that could be it....let me know what you guys think, i really cant figure this out... Thanks!
well the valve seals were the first thing we replaced... and just got done with replacing rings... and it still smokes... also the first time we tore the engine down there was some water on the top of the piston... so we replaced the gasket as well but it still smokes
im hearing some people say they think the compression ring could be in backwards, which makes since but why would the bike run good for 20 hours and then randomally start smoking if the ring was upside down? anyone think that the left crank seal could be the cause?
List for a smoking engine possibility
First of all, be sure your burning oil, not your coolant.
Coolant gonna smoke white and smell sugar
Oil gonna burn blue
Coolant burning possible cause in order
Wrong head gasket
Warped cylinder head surface
Warped cylinder top surface
Cracked cylinder water pass
Cracked cylinder head
Wrong or missing ORing
Oil burning possible cause in order
Wrong or missinstaled ring (side and alignement)
Scared cylinder liner
Wrong piston
Wrong valve seal
Wrong valve guide
Wrong valve steam
Wrong head gasket
Wrong piston axe
Cracked cylinder in oil pass
Clogged PCV hose
Wrong Crankshaft rod
Wrong Crankshaft rod bearing
Wrong Crankshaft cage
Wrong Crankshaft bearing
Cracked crankshaft case
You CAN'T have another reason
Edited by DarkCRF
So
Backward install ring is a good guest in our case. Carefully inspect your head and cylinder for crack and really check the contact surface for warpage.
No, your left crank seal can't be the cause.
yes it is burning oil. its blue. and the valve seals i know are good, cylinder is good, crank is good, bearings are good, there are no cracks, piston and rings are the right ones. so you dont think that the ring being flipped wrong would cause it? the compression ring?
Oil gonna burn blue
Wrong head gasket
Wrong piston
Wrong valve seal
Wrong valve guide
Wrong valve steam
Wrong head gasket
Wrong piston axe
Clogged PCV hose
Yeah maybe, but stop doing supposition and inspect EVERYTHING carefully. Start by the beginning.
so im starting to think its the rings/cylinder.. cause i didnt have the cylinder honed and i didnt do the ring gap.
Pull the head and cylinder and look for a broken ring. Its possible that your ring end gap was too small and broke one or more of your rings. Or possibly your oil rings are installed incorrectly, or you didnt stagger your ring end gaps properly.
What Keith said or the exhaust valve guides. The exhaust valve guides are real common to go bad, especially the older bikes with some hrs on them.
