Couple questions about land
How much land is typically needed to build a nice track on? How hard is it to clear if its wooded? Whats needed to remove trees and stumps?
I have 30 acres but it seems too small. 40 acres may be the starting point. A square 40 is a quarter mile on each side.
I cleared with a chainsaw and cut the stumps flush with the surface. I can mow over them. I am good at sharpening my chains quickly. That helps if you get the saw in the dirt.
mentioned above, i'm guessing, is for a mx track, you can build a decent sized sx track on slightly larger then a football field sized lot
