GPR stabilizer on ktm
I have a 2012 ktm 200 xc-w I just put a GPR-4 steering stabilizer on & the throttle cable is short to begin with when turn the handle bars the cable rubs on the stabilizer knob & turns the settings so I zip tied the cable to the gas vent line has any one ran in to this problem & can I get a longer cable? Fast ktm
I'm sure every one will jump in since this has been covered. Just run your throttle cable on the right side of the frame and safety wire both ends at the carb and the grip. Or get a fastaway cable and run it in with the other cables out front.
Motion Pro make's a killer new cable for KTM's,Part # is MP-10-3000 T3 Slidelight.It is 3" longer than stock,Thread's into throttle assembly and carb top.No need for saftey wire with this cable,I just got one and it is super trick!!!Cycle Buy.com has em for $32.99.You can run it through the triple clamp's or off to the right or left.Very cool for a cable!!
