01 CR125R seizes bolts
hello everyone im new to this site, i run in to issue with my 01 CR125r. i was hoping someone would be able to advise me something. I bought my cr 125 from some kid that didnt really take care of it:bonk:. So my issue is chain tension bolts, they are seized. if anyone knows how to fix this cheap and easy please let me know. i have some ideas but id like to hear your opinions. Thanks a lot everyone!
thanks i got it i found all the info! thanks
Lots of PB blaster and then heat (with a torch) when you want to start working the bolts loose. If that doesn't work, consult a machine shop.
thanks! in canada they try to charge up the a$$! I ll try t do it mysels if cant work it ill use swing arm buddy! thanks everyone! shity that it happens so offten to so many people!
when you get them out, put a light coat of something like Anti-Seize on the threads, this will reduce the chance of happening again. I personally use a light coating of water proof grease on mine.
