07 kx250f won't start, need some help
Alright I've got an 07 kx 250f that won't start. I kick and it doesn't really do anything except slightly backfire after a couple kicks like its loading up and you can smell gas. Its been sitting for about 4 months as I've been off at college... So I've cleaned the carb, fresh gas, new spark plug. Valves need to be adjusted I'm sure. Anything else I should look for? Thanks for the help! Sorry I would use the search but I'm using a cell phone and it won't let me use it for some reason.
carb and valve adjustment...those are really your two main things..also use the search on the site...This question gets asked a lot.. I had the same problem with my wifes 07 and we had to push start it a few times when cold..then it would start easy all day... The valves where the problem, adjusted them and it started fine ever since
