Accel pop
I have a acceleration pop on my 05 450x after moving the clip on the needle up one, because i thought it was getting to much fuel, i think i was wrong, i think i just had a dirty carb, would the clip being one higher cause it to be too lean and make it pop on acceleration?
thats where it happens, it doesnt start right away, it starts at probably about 1/3 throttle
You describe it as an accel. "pop", what does it do at about 1/3 throttle when you hold it steady?
You could always put the needle back up (clip down) and see if it goes away.
I did move it back and it helped but its still poping some when i hold it steady at about 1/3 throtle. Should i move it down another clip?
I just followed the jd jetting instructions, 165 main, red needle with the clip in the middle,i also changed the pilot jet to a 52, which fixed a decel pop i had, i installed a different fuel screw, easer to get to, and the mods done are, smog block off, air box opened(top and sides) and backfire screen removed, R muffler, pink wire mod.
