ktm 300 shock length from 08-10
i have a post on this in suspension forum but with no luck, maybe i can get some help here..
i know the shock for the newer model for the 10 and 11 ktm exc or xc-w or TE berg models have altered shock length.... i believe 7mm shorter correct me if i am wrong!!!
how do you measure this? is it fully extended ??
Also does that mean if is shorter 7mm the whole travel is less by 21mm???
thanks
The 2011 has a longer shock positioned at more of an angle. I believe the rear suspension travel remains the same as 08-10.
okey i see, so shocks from previous years would be shorter if you try and use those???
run out of length??
