01 CR250 footpegs
00-01 are the only years that work. (125&250)
I welded a bigger set of teeth on my
OEM ones just to make them wider.
Newer gen 3 pegs are easy to convert to your gen 2 brackets if you are going for fastway F3's.
I have an original set made for the gen 2 which have been discontinued and New sets of gen 3 pegs. Basically the same peg, just needs a longer bolt to shim the camber up.
is a lowered peg for the gen 3 available that you can make work in the 2nd gen?
I welded and milled some -04 cr250 footpeg attachments so i can run newer ones bolt-on on my -01 cr250... works great, ill post a pic if i can find any!
