Cooling system help.
Hey guys, I have a 2010 XCW530 Six Days that I has been having some overheating problems. One problem was my radiator fan was not coming on. Fixed that but I was still over heating to the point when I would stop and shut the bike off it would not start until it cooled off. I pulled the T-Stat out and checked it and it looked like it was sticking a bit so I pulled it out and put a larger o-ring to seal the cover. Now my question is, have any of you just pulled the damn thing out and run without a stat??? I didn't have a t-stat in my WR and it ran fine and most of the dirt bikes I've ever seen don't have t-stats in them. So what do ya think???
For some reason KTM has been supplying their newer fan kits with a too hot 100C or 100/95C thermo-sensor. You would be better off replacing the stock sensor with an inexpensive 95/90C sensor from the '04 BMW 318i available from you local auto parts store (like NAPA).
I pulled the T-stat out of my 09 450, plugged the little bypass return to the radiator and also went to a waterless coolant. Works well now. When you look at the thermostat opening, set at full open, it looks restricted to me.
Cool deal thanks.
Do I have to plug the bypass return line??? Is the bypass line the one coming off the bottom of the stat housing? The hose that looks like a p-trap?
It should not make a diff.Once the t-state opens up its the same amount of coolent going thru if its in or not.The only diff would be in faster warm-ups.
I would check the jetting.If you have not rejetted they are supper lean from the factory.
Cool thanks, that's kinda what I was thinkin. I was talkin to a buddy last weekend and he said pretty much the only reason for the stat is for warming up the motor fast for racing. I don't race anymore so I am good. I have ordered a JD kit for myself for Christmas (woohoo) as soon as it comes in I will install it. I already talked to James Dean himself and give him all of my info and he gave me a good starting point so I'm good to go... :bonk:
