Need help with valve stack on CR85 forks.
So I pulled my forks apart, these are for a 2004 CR85 used for mini road racing. I have .44kg springs and using 20wt oil. I'm trying to change the stack to use stock 5wt oil and not dive as much when I'm under hard breaking. I have lowered it 3" and would like to get the valving close.
For reference I'm 170lbs with out gear and use the bike for GP style Mini road racing. The stock stack is;
(shims are actually measuring 17.9 so ill assume they are 18.)
Compression:
18x10
18x10
18x08
18x17
18x17
18x17
18x17
18x20
Rebound:
18x12
18x12
18x12
18x12
Any help would be greatly appreciated..
Edited by Tepco
Shim size correction
you need the restackor program for a job like that
I have never seen that before, thats pretty cool.
