****ed up my engine!! now how should i fix it?
well i cleaning my engine and broke my push rod my power valve, i put the engine upside down. Part number 3
well i have another push rod im just wondering if i could just take off the right crankcase cover without taking off the right.
Yz 250 1997
Just take the right cover off. Worst case you tare the gasket and have to get a new one. You should be able to take that cover off without taking your clutch apart or having to take the engine out. You have to take the right cover off to unbolt 7 from 3 so 3 can slide out to be replaced. next time you take it apart hold 3 so you dont brake it taking the bolt out.
I think yamaha (and im guessing others) has a little hole to put a small screwdriver or something in that blocks that rod in place while you take the bolt out. THis way you arent prying on the push rod.
