Cam Chain Tensioner Install
I just reinstalled cam chain tensioner after installing cams and doing a valve adjustment.I have repeated the steps as per the instructions in the sticky .It is way too loose.The tensioner is working properly and i have the timing correct.When i say loose i mean i can grab the chain in between the cams and move it a good 1/2 inch up and down.....
How many clicks can you hear it click out when you put the spring,rod and cap back on?
Check the chain hasn't slipped off the gear behind the flywheel, Had that happen to me before !!
without checking it again...maybe 4-5 clicks and when i rotated the motor it may have clicked once more...not sure though...i can redo it again and count them...i dont believe it has slipped off the bottom gear because i rotated it and it came around and was back in time ....
Edited by walent215
Strange, it should be pretty tight between the cams, only allowing for a few mm of play up and down.
If the tensioner only clicks out 4-5 clicks, and the chain still has slack, something must be stopping the tensioner from going out as much as it needs to.
Remove the tensioner, check it for wear, reset it, put it back in with the teeth facing in/up and try again.
