handlebars and bar risers for txc511
Any idea if I'll have to put on longer lines if I install taller bars and bar risers on a TXC 511? Are KX highs the tallest widest bars out there without having to go to ATV bars?
Have you already turned the bar mount around 180 degrees to get it in the furthest forward position? From there you can easily get some solid bar stock and cut it to the length you wish to rise the handlebars, drill the necessary hole in it and get a longer bolt for the riser clamp and make your own custom riser for cheap. I'll have a Scotts/BRP stabilizer mount and riser available within the next month as I'm designing my own to move the bars forward a bit but these do provide for a 10mm rise I think, however the handlebar is centered over the riser bolts.
