suzuki 2011 rmz 450
i own a 2011 rmz 450 we have just done the oil seals in them, we got 1 back together and wen trying to put the centre bolt on the bottom it will go on but wen we put it back in the bike the clicker just keeps goin round with no stopin adnd it undoes itself of the bottom not wat use think is wrong with it csnt seem to see aqnything?
did you forget to install the rebound adjust rod? If you put that in, pull the bottom rebound adjuster bolt out and make sure the bottom of the rebound adjuster rod isn't messed up. It should have a flat side that the adjuster screw shaft sits against. If it's totally round it got messed up when you installed it.
