Yamaha My Yamaha Blaster acts like the clutch is pulled in, no matter what gear its in
I have a Yamaha Blaster that I just got running, the clutch dosent seem right when you pull it in. whenever you put it in gear, no matter what gear, it acts like your holding the clutch in. I have tried adjusting the clutch at the lever but this obviously didnt fix the problem, any ideas?:bonk::smirk:
What kind of oil are you useing? If that is up to spec. then take the cover of your clutch off, and look for groves in the cage if you have them and they are deep you'll need a new clutch. Check that out and get back with the results. GOOD LUCK ....GREASY.:bonk:
did u line up the dots on the hub and pressure plate... the arm the cable hooks to has to line up with the arrow on the case too
