06 polaris predator 50
so i bought this quad knowing that the electric start wasn't working, but i am at a loss as to where to begin. if i jumper out the solenoid it will work, if i kick start it it will work, but no button start. also the horn dosent work. when i test the positive wire at the battery i get 13 volts but when i test the wire at the harness for the key switch i get 7. before i destroy the wiring harness i wanted to ask for advise.\
thanks for any advise.
I would probably just replace the entire thing because you dont know what the jackass did before you to mess it up...if the wire is that messed up then its probably going to short out some other place...
