New EXP installed...quick question
Installed a Rekluse EXP a couple of days ago. Installed high engagement springs, set screw turned out 1.25 turns from "hard" stop and everything buttoned up. Broke it in per Rekluse directions and busted out a great 60 mile ride.
Performed great but a few times I noticed a low sounding squeal when rolling on the throttle that went away as engine RPM's ramped up. Is that normal? Is it the clutch engaging?
I plan on pulling it out and putting in low engagement springs for faster response.
Thoughts?
Had the same thing happen. either with the spacer or the rekluse cover, it now needs more oil. check the oil level with the check bolt, sounds like it is low, mine was.
I added oil and all was cool.
No o-rings came with the kit. Bike is 2009 KTM 400XCW.
@T-Roy...what type oil are you using?
Exp 2.0
Can't afford core right now.
o-rings are with the core.
I run rotella in my trans side with the Rekluse as Rekluse recommends.
I use either rotella 5-40 or mobile 1 10-40. both full synthetic.
Did you check to see if the oil level was up to the check bolt?
Being Christmas, nothing open so unable to get oil but will do so first thing tomorrow. Also installing low setting springs...and cleaning up all bearings, etc... light winter maintenance!
