clutch clearance issues on 2006 crf250r
Whenever motor gets hot i loose my clutch? i found a pro x clutch clearance rod but will they work on the 2004 through 2007 hondas?
Yes it work. I have one in my 2009.
They added a judder spring in 08. If you have an 08 or 09, order a clutch for 04-07. Remove the inner friction (1/2 the size) and the judder spring and replace it with a full friction. If you order the clutch kit for the 08/09, it comes with the smaller friction. The judder spring does absolutely nothing.
