rmz forks in drz?
The width of the hub will be different (drz being smaller) as well as the axle size (once again, it will be smaller). the disc will probably not line up with the brackets for the caliper. Could you get it to work? probably. Is it going to take a bunch of work? probably. Then again, if you have them side by side, it may be closer then it seems (I basicly tried the same thing but with honda components...it was not even close. Not worth doing. Also keep in mind that just the added length in the fork will make your bike a chopper. The front end will be way to long. And make sure the forks clear the tank since they will be much wider at the tank due to the triple clamps placing the forks farther apart.
Tom
