Rekluse Core EXP or Z Start Pro
I ride hare scrambles and was wondering if I should go with the Core EXP or with the Z Start Pro. I want the anti stall and still want to be able to feather the clutch. Which should I chose
I own a pro in one of my ktm's, and a exp core 2.0 in my gasgas, either works, the pro will give you a softer lever pull, and the lever pull changes with rpm much more, lower rpm is like butter, higher is stiffer
I think the pro is smoother, but the exp has a lever pull that does not change so much with RPM
If 300 dollars more to retain the exact same clutch feel as stock is worth it then go with the EXP Core. I had to buy the core as it is the only one that they made for the GG.
I dont think it's exactly the same, but it's close
I too had to get a exp-core because they dont make anything else for my bike
I miss the dynaring, they were cheaper and supported older bikes, unlike rekluse
