DRZ400 stock rear spring ? is it a race tech
I can't comment on any other rates but my Rachtech 5.7 is blue.
On the spring somewhere it will be marked what rate it is:thumbsup:
OEM Suzuki spring is white.
K and E have the same spring rate = 5.3kg/mm
S and SM have the same..............= 5.5kg/mm
Most E models I have seen are white, SM mostly red, so would S models be blue?????
The race tech spring will have numbers on it for spring rate. That's the only way to tell the KG spring rate. No doubt if its a race tech spring then it's not stock. For most but the lightest riders the stock spring is too soft.
I just got ahold of original owner, he forgot to tell me he had the rear and front redone with the race-tech suspension. what a score he weighs same as me.
With your luck it could be time to take some lottery tickets..:bonk:
