New KLX 400 / DRZ
ET Al; I just pulled the trigger on an 03' KLX 400 and I found out that it is a DRZ too! Anyway, does EVERYTHING swap?
I need / want to put a bash plate, maybe a bigger tank, kick start kit. It already has slim line blinkers and a nice tail rack.
Any suggestions?
Merry Christmas all.....
did you get stuck with the sucky green plastics too ?
i'm kidding man, the green looks great. same bike, stuff swaps fine. the klx is just hard as hell to find in the wild anymore.
enjoy, merry christmas back atcha !
What model have you got...?.
The 2003 KLX400r and KLX 400sr are just green DRZ’s.
R is a E model and SR is a S model.
If bike is stock and it's got a slant body Keihin carb , I would suggest you have the R model..
SR will have the mikuni carb
Yes everything swaps, it is a Suzuki in green clothes. Basically a 2003 DRZ S or E in a different color.
Any suggestions?
Do the relibilty fixs found in the FAQ,
Locktite fix the counter shaft sprocket, counter balancer nut, primary nut, stator screws, flywheel/starter gear fasteners.
Remove the rear suspension and swing arm, clean and grease the bearings.
Remove the steering stem , clean and grease bearings.
Do the free power mod
Install a Manual cam chain tensioner.
Install Case Savers.
Round over the back of the shifter
Install radiator Guards
Hyde Skid plate or Light Speed CF 3 piece set Or a TT aluminum skid plate
Then some other stuff for a better feel and ride.
(KLX400 SR)JD Jet kit for the stock BSR36 carb and the 3x3 air box mod. Or KLX400R) JD Kit for the FCR39 Slant.
Install SS brake lines front and rear.
Re Spring and valve suspension to suit your riding.
Install MRD SSW exhaust
Edited by E.Marquez
Well I really should know more but I bought it from a friend down the street and then left town.
Yep it is Black/Green...
......can I add the Kick Start conversion?
..........How do I add Pic's here???
Thanks
xr650L
xt 250
bmw 1200 GS
Edited by captnmack
added stuff
The bike is actually manufactured by Suzuki in a joint marketing deal that they had with Kawasaki....anything that is made and sold for a DRZ400 will fit, as what you have IS a DRZ in Kawi clothing!
I have one of each, one green, and one yellow.....the two fastest colors I might add!
And yes, the kick start kit will fit....:bonk:
add pics by going to www.imageshack.us uploading the photos, and then pasting the link in the text box after clicking the yellow add picture button...its the second to last button above where you type.
