Nissin Front Master Cylinder Kits
Hello, am chasing some information in regards to Nissin Master Cylinder rebuild kits. What I want to know is whether there is anyone that sells just the 2 rubber cups/plungers that go onto the steel piston shaft. Every time I have had to re-build any master cylinder the only thing that is stuffed is these two cups/plungers. Unfortunately, I haven't been able to buy these items individually and end up buying the rebuild kit containing a new spring, piston shaft, circlip, washer etc that I don't need, and at the same time shelling out AU$60+ in the process. The frustrating thing is that the cups/plungers are probably only worth 20c.
Any information would be greatly appreciated.
Cheers, Stauno.
