2006 kx 250f engine filters?
no, oil filters got its own cover by the waterpump and there is a mesh screen you can get to if you pull the right engine cover off.
thx, I was talking about the mesh screen,I would need a new case gasket then.
clutch cover gasket and engine cover (inner clutch cover) gasket. Also probably want to get a new waterpump gasket too.
are you talking about the twin screens for the scavenging system? or the primary oil filter?
if you're talking about the twin screens yes they require a full engine tear down to clean or replace..
yes the twin screens...how do you know if its needed,anyway to check?
if you drain the oil and take the stator cover off, i believe you can get a peak at one of them.
thats only on the 09 and newer..
I guess if you look through the oil return you can catch a slight glimpse of them.. Still does not change the fact that you can not change them with out splitting the cases
