2000 cr125 brake caliper mount compatibility
Got a line on a 2000 cr125 that I'm considering to pick up and slap some supermoto wheels on. Looking at the parts fiche it's not clear what is the caliper mounting on the fork compatible with. 45190-KZ4-J21 is the part number but it's listed as used for both 2002 and 2004 crf450r, which I know for sure has different caliper bracket and bolt spacing.
Anyone got an idea if it's compatible with later model CRFs or with early 450's? If someone can just measure the bolt distance where the caliper bracket is bolted on to the fork leg, that'd tell me which one is it as well.
Thanks in advance!
honda used the same caliper bracket from like 89-03. Then the 04 current is the same shorter distance between than the previous years.
Got it, so they changed 125 in sync with the 4-strokes, thanks! :bonk:
