05yz125 footpegs fit yz450s?
hey guys, im looking at buying some wide 08+ footpegs and brackets.
ive found some 05yz125 pegs and wondering if theyre the same?
You don't need the brackets, the wide 08+ footpegs will fit right on the 2 strokes. I have a set on my 06 250.
i need the brackets because im welding them on a steel frame;)
ive found some 125 ones for sale but i love my mates wide 2010 yz450 pegs
Pretty much all the Yamaha pegs will work and are interchangable between 125's, 250's, 250F's and 450F's. The aluminum frame bikes have the brackets that bolt to the frame and the steel bikes have the brackets welded to the frame. If you want the wide and low OEM pegs you'll need to get them from 08+ 4 stroke.
Check this post for everything you need to know about pegs ->http://www.thumpertalk.com/forum/showthread.php?t=887077&highlight=pegs
thanks mate, just the info i was after. think im after these ones
5XC- Stainless steel, 55mm (around 2 ¼”) wide, 83mm (3 ¼”) long, 5mm (around ¼”)
