Pressure plate bolt not coming out
i went to remove the clutch on my 1992 KX250 and 4 of the 5 bolts came right out but the last one just spins and spins but wont come out. how the hell do i get the dang thing out?
sounds to me like you one: either stripped the inner hub or two: broke the inner hub. either way, you will need a new inner hub. if its striped and not coming out, you could try to wedge the washer with a screw driver and try to back the bolt out. if you cant get a screw driver in there, you may actually have to break it to get it out. but thats my guess. never seen a clutch spring bolt strip out before.
well i finally got the bolt out. i had to wedge a screwdriver in the spring and hit it with the impact gun. and to my surprise this is what i found.
http://i1185.photobucket.com/albums/z343/Jeepinitreal/IMG_0367.jpg
the previous owner broke the stud off and just threaded a bolt through the other side of the hub to hold it on. this apparently is what caused my clutch to not disengage
looks like that push rod has seen better days too
as for the pictures you need to use the code link here
