XR500R Transmission
Can't be sure without looking at a manual,,I suspect a stripdown to the gearbox may be needed to get at the problem but can't be sure without looking at the 80s manual and how its gear lever works.,
Heres the fiche anyway,,
http://www.servicehondapsn.com/fiche_section_detail.asp?section=190435&category=MOTORCYCLES&make=HONDA&year=1980&fveh=4298
Looks like possibly part 21 has broken or maybe come adrift..Circlip which holds things in place.,
Still hard to say about the splitting cases as the details not layed out in a form I can understand.,,My guesstimate is still that the bottom casings would need seperating to get at the shaft.,
OK, thanks. I have the left side crankcase pulled off it already (about 3 months of penetrene and WD40), I will have a look and see what its like
Should be a c clip aroung the shaft on the inside of the outer case. They sometimes pop out of the groove i nthe shaft.
