Kick starter problems 1995 cr 250
Hi everyone
Since i have had my cr the kickstarter has always rattled against the expansion chamber ,apparently there is a bumb stop mechanism to stop you snapping your ankle when it kicks back
Does anyone know how to fix this problem or has anyone herd of this before
Thanks heaps
It's probably from wear at the pivot where the kicker attaches to its swivel base. All older bikes have it to some degree. Either replace the worn parts, or prevent the metal-on-metal rattle by putting a zip tie around the pipe or the very end of the kicker.
I have the same problem. I was thinking about moving the kickstart lever one spline going clockwise on the shaft. This puts the end of the lever lower than the expansion chamber and above the case. But like I said, I haven't tried it yet. Maybe someone who knows for certain will post.
***This is inaccurate. See post 7 for correction.***
Edited by coopou812
get a new one. there is no way to fix it unless you weld it and machine it back to size.
its just worn out. plain and simple.
3 possibilities
1) kick starter is worn out
2) pipe is bent
3) kick starter assembly alignment dots are not aligned inside the cases
I've had 1 and 2 on my bike before and 3 on a friends bike who had someone else put it together for him. I don't know what the frame and pipe clearances look like on the 95s but these are my experiences with the 2nd Gen aluminum framed cr
Oops, I got this backwards. I meant to say move the kickstarter one spline counter clockwise on the shaft. The end of the kickstarter will clear the expansion chamber and rest below the tank. This would shorten the kicking stroke. Again, I haven't tried it.
just replace it. i tryed just about everything on my 96. shiming it...everything.... nothing really dose it.
Thanks. :bonk: I was really hoping not to have to buy new and I don't trust used and unseen for this part. I'll add it to the list.
