coolant level
I'm rebuilding the top end of my RM 85, and when I drained the coolant, only about a pint came out when my bike calls for 1.2 quarts of coolant in the radiator. Should I be worried? Or should I just continue with the rebuild and fill with the correct amount of coolant? Thanks in advance.
Drain the gearbox oil and see if it's milky if so you may have a water pump seal that's bad.
If the coolant was brownish that you drained out of the rad. you may have a bad head gasket or warped head.
