crf fuel injection conversion??
can you convert a older crf 250x or r to fuel injection and how?
Yes, by changing the motor, CDI, ECU, and fuel tank.
The real question is why? You can get a CRF250X to run perfectly with the stock carb!
You can buy everything you need for around $7,500.....
AND they throw in a brand new 2012 CRF250R to make it easy to carry all the parts home; the parts are all already attached and operational.
Couldn't be easier :bonk:
yeah no sh*t i went to cheap cycle parts online and seen some of the parts to do it where as high as girraffe pu**y i was was just curios if it was possible to do it and if anyone here was smart enough to know how.
yeah just curious im thinking about building a crf250x supermoto from the ground up and kinda figuring out witch motor to use?
If you want a FI bike, it is cheaper to buy one that has it from the factory.
Not only do I know how to do it, I also know doing so is a waste. Those that do build a FI setup do it because they want the challenge and the money does not matter. It is not a do-it-yourself job if-you-have to-ask sort of proposition.
LOL, ramz hit it on the head!
