Linkage
What do you think is the best/cheapest lowering link to get for a 11 450. i am an A rider and im broke and have a lot of money in suspension work but dont have the link and i have trouble with everything that the lowering links say that they fix??
Cost zero $: Have you tried raising the fork caps to 13mm above the triples, and then resetting the rear sag (lower rear a few mm) to restore turning balance? I understand that will make the rear feel initially a bit softer, but it'll certainly make the bike feel lower and less top heavy.
Cost about $40: Then you could find out if any of the other year model bikes have a longer link pull-rod, and if so, then buy one of those used, and put that on.
I dont know which years have what length pull rods.
In my 06, I've been using an 07 rocker arm with the 08 (2mm longer) pull rods, and I like it. Cost me 2 x $40 for each set on ebay. Way better for me than the stock 06 setup, and a few mm lower too.
