Honda cr125??????
Hello guys and ladies,im new to the motocross and im having problems with my front wheel.when loosen the nut the wheel spins smoothly but soon as you give it a few turns on the nut its really hard to spin the wheen.I have seen that the disk is dragging on the calipar but why i dont know.i have had new bearings in the front wheel.Its really pickling my head can any one sheed any light on it for me? the yearof the bike is 1994 :bonk:
did you reinstall the center spacer between the bearings in the hub? did you get the spacers on the correct side?
if my memory serves me right there is only 1 spacer on the front, goes on the caliper side.
i'd pull the caliper off, tighten wheel. that'll rule out the bearings n such. as you spin wheel with caliper off look for rotor warpage.
if its good then its in the caliper. maybe, look at the amount of free play at ther lever.
my son had once adjusted all the free play out of his rear brakes and that caused the caliper to drag badly.
bleed your caliper too.
did this just start? may be ur bearings arent seated all the way?
when the rotor drags is it dragging on the inside pad or the outside?
Ok I will try that thank u.it is dragging on the left side aganist the caliper.took the pads off to but didn't make any difference
is that the leftside when ur looking at it from the front? weird? even without the pads in there it rubs? dang, im gunna go out and look at my 93cr125.
It's the right if your looking at it.so if your sat on it its the left side.I know yes it gets worse when u tighten the wheel nut.my friend suggested putting a washer on as well to push it away from the caliper.it is very strange don't u think?
yeah thats weird. maybe like i said earlier, its possiblr that your bearing isnt seated all the way or seated too far to the right.
try and push the caliper piston back into caliper, open the zert fitting. put back together with pads see it that helps. mybe someone or some how the front brake lever got pulled with tire off, which would push that too far towards rotor.
http://www.mediafire.com/download.php?9abxrwvnsd28v5k
http://www.mediafire.com/download.php?5rarjku3674uvif
http://www.mediafire.com/download.php?kl7boh7k3dlzps4
Here's some pictures of the front wheel with the spacers and the caliper were the disk is rubbing on the calper case.you will have to download the pics.but please let me know what you think of it?
That mediafire link didnt work for me.
anyways, reading I think you have the center spacer misaligned causing the bearing to not be seated. I would take it all apart, check the check all bearings are seated. in fact knock one out and recheck the center spacer.
he's said there is no way they were done by a machine putting them in.I wiould say tho the disk is very worn would that of warped the disk at some stage?
If I'm reading this right, everything was fine in the beginning...you changed out the wheel bearings...now the brake is dragging. Right?
Did you do anything else? Put in new brake pads? Remove the caliper? Anything?
With that said, I've had things like this happen to me before, and it's because I didn't put the parts together correctly (even though I "followed" the manual). My suggestion: Start over. Take everything apart and put it back together again, and follow the diagram in the manual (again). You will find out what you did wrong soon enough.
I had a chap who's a pro with car's do them for me because he has the equipment.what has happended since i had the wheel back me and dad had trouble putting the spindle threw it got jammed so i think that might be some of my trouble?
http://www.mediafire.com/download.php?40ud9k819wyq214
http://www.mediafire.com/download.php?s32s42ijji1875z
http://www.mediafire.com/download.php?1ewq2z3clz6e83p
Right here are some more pisc of the bearings housed and looking at the housing my problem is the wheel its shot in the housing the bearings are snug but there is bits of the housing were they sit missng and chewed up? But im am open to suggestions from all of you guys if im right or wrong :bonk:..HAPPY NEW YEAR TO.
