DMC Afterburner on 2005 CRF250R
Anyone know if the DMC Afterburner Comp or Quiet will fit on a 2005 CRF250R without modifications (bolt on)? All the info I can find says they are for 2006-2008 but are sold for single exhaust. Seems like it should fit a 2005 as well if it is single exhaust not dual. Or is it taking the dual to a single exhaust and won't fit a 2005?
Link showing it will fit 04-08:
http://www.ebay.com/itm/DMC-AFTERBURNER-COMPLETE-EXHAUST-04-09-HONDA-CRF250R-X-05-09-450R-X-DIRT-BIKE-/280794673526?pt=Motorcycles_Parts_Accessories&vxp=mtr&hash=item4160aab176#ht_2789wt_1180
Link showing it is only 06-08 but same part number:
http://www.jcmotors.com/p-13143-dmc-afterburner-comp-off-road-motorcycle-full-exhaust-with-anodized-muffler-for-honda-crf250r-06-08.aspx
Thanks.
Since it's a full system, about the only issue where you're probably going to run into a problem is where the system bolts to the subframe. The 04/05 subframe is different than the 06-09 primarily where the exhaust bolts up. There's not going to be a clearance issue with the air box. Guys were trying to put duals on the 04/05 and found out that the air box is different and the mounting bolts.
