Removing Pipe Guard Mounts
Has anyone ever used a Dremel or other tool to remove the two mounts on the header that holds the pipe guard on? I was thinking that you could easily grind off the two mounts (they are welded in 4 spots, 2 for each mount) and then smooth it out with a grinder. But I don't really have any "metal working" experience and was wondering if it will work or if anyone has done this before.
Thanks!
a friend of mine has done just that on two yamaha headers. ya can't tell the boses were even there.
I was playing with mine after this post and the mounts cut off easily (well I only did the bottom part of one, so it's still there) but where they were welded was going to take a die grinder or something different than a Dremel. So I left them on there for now.
