oil drain plug
hi guys i did a search and didnt find the answer to 1 question.
I have a 05 yz 250 and my sump has being stripped of it's threads,so i am gonna insert a helicoil but there is a small hole on the left side of the threads in the sump so if i put in a helicoil will it matter if i block this hole :bonk:
What is this hole for?
I dont think there should be a probelm because when the bike is running the oil will be up in the gearbox and clutch.
Any advice would be greatly appreciated
Thanks
Colin
You will be fine... seen it done many times. Someone over tightens the drain plug, strips the threads, and ends up needing a heli coil inserted. Works just fine!
